grhsc
Viewing 15 posts - 31 through 45 (of 69 total)
  • in reply to: role inheritance #13552
    grhsc
    Sorry for asking an invalid question, I forgot to save it before uploading. When I saved it, it work.
    in reply to: New release Rapid SCADA 6.1.x #13220
    grhsc
    Dear Mr. Mikhail,
    where can I download the previous version of Rapid SCADA? for example, if I want to download the 6.1.1 linux version.
    in reply to: How to configure mqtt client of V6 #12544
    grhsc
    Dear Mikhail, could you keep helping me please?
    I met new problem, based on your script, I wrote script to get data. Because the target data is about 200, I can’t define them one by one, but use such a loop
    https://drive.google.com/file/d/1lDt15k4eTqIaBvb-F64ZabLB8jcbPp0k/view?usp=share_link
    However, a problem was found in actual use. The mqtt client setting of the other party is: only the quality is good to publish, and the bad one is skipped.
    For example: 200 tags, but occasionally there will be 5 bads in the middle (like it is between 50-54). The data parsed in this way is only 195, and the above program leads to data misalignment.
    The program makes 1-195 always have data, instead of skipping wrong tags, let 1-50, 55-200 have data
    in reply to: How to configure mqtt client of V6 #12540
    grhsc
    Thanks for the example, it worked.
    “Probably, support of certificates hasn’t been implemented yet by MQTT client communication channel.”
    For Internet communication, TLS seems to be a must, hopefully it will be supported in the future
    “The driver works with current data. If you mean that the Timestamp field in JSON specifies historical data (in the past), the driver should be modernized.”
    I currently need real-time data only. But this is interesting, how to write the data somewhere (dat file or database?) It will be able to do the data source of rapidSCADA?
    in other words, is it to create a new data interface/Drive and get the data directly without using the existing driver?
    Can you provide relevant information?
    in reply to: How to configure mqtt client of V6 #12535
    grhsc
    Dear developer,
    These 2 questions I’ve found through testing, they are in the logs.
    After completing the setting in the last step, where should I check the subscription payload?
    How to turn them into variables in rapidscada?
    This is the questions I still need your help
    1. use self signed certificate
    2. If the the payload format is like this, how to set up JS?
    {“data”:{“A_CV”:3391.09,”B.F_CV”:3402.010986328125},”Timestamp”:”2023-05-05 08:59:45.947143″}
    thank you!
    in reply to: Chart not Displaying Data #12533
    grhsc
    Of course, just avoid using ” * & @ “in (custom modified) xml files
    in reply to: Chart not Displaying Data #12479
    grhsc
    I have a similar experience, I’m not sure it will apply to you, just for reference.
    You may have modified the xml file of the system or applied a special tags name, you may have added a special character @,&
    If you can take a full screenshot (whole screen) maybe I can confirm this
    • This reply was modified 3 years, 7 months ago by grhsc.
    grhsc
    Rapid SCADA version is 6.0.1, and I confirm from the “C:\Program Files\SCADA\ScadaAdmin\Lib ” dll file information, I use Chart Pro is 6.0.0.1
    This is a simulation test in a LAN, it has no Internet IP address. If you don’t mind, can I provide teamview for your access?
    (You can choose from Wednesday afternoon to Friday this week, or next week, and leave a message here, I will send the access information to your email in advance, and I will open teamview online on time)
    Or use google meet to share the screen and communicate online
    sincere thanks
    • This reply was modified 3 years, 8 months ago by grhsc.
    grhsc
    Do you need me to provide sample data for testing?
    But I don’t know how should I extract some data. It’s too big to send it all to you
    grhsc
    In the console image, could you switch the second “Console” tab to Console also? And then press F5 to refresh the page and get messages into the console.
    (edge), 1 month, from 2-16 to 3-15
    Time offset is 2023-02-16T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:704 Chart loading state is FAST_LOADING
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-16T16:00:00.000Z to 2023-02-17T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-17T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-17T16:00:00.000Z to 2023-02-18T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-18T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-18T16:00:00.000Z to 2023-02-19T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-19T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-19T16:00:00.000Z to 2023-02-20T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-20T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-20T16:00:00.000Z to 2023-02-21T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-21T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-21T16:00:00.000Z to 2023-02-22T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-22T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-22T16:00:00.000Z to 2023-02-23T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-23T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-23T16:00:00.000Z to 2023-02-24T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-24T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-24T16:00:00.000Z to 2023-02-25T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-25T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-25T16:00:00.000Z to 2023-02-26T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-26T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-26T16:00:00.000Z to 2023-02-27T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-27T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-27T16:00:00.000Z to 2023-02-28T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-28T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-28T16:00:00.000Z to 2023-03-01T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-01T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-01T16:00:00.000Z to 2023-03-02T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-02T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-02T16:00:00.000Z to 2023-03-03T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-03T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-03T16:00:00.000Z to 2023-03-04T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-04T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-04T16:00:00.000Z to 2023-03-05T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-05T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-05T16:00:00.000Z to 2023-03-06T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-06T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-06T16:00:00.000Z to 2023-03-07T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-07T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-07T16:00:00.000Z to 2023-03-08T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-08T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-08T16:00:00.000Z to 2023-03-09T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-09T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-09T16:00:00.000Z to 2023-03-10T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-10T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-10T16:00:00.000Z to 2023-03-11T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-11T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-11T16:00:00.000Z to 2023-03-12T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-12T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-12T16:00:00.000Z to 2023-03-13T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-13T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-13T16:00:00.000Z to 2023-03-14T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-14T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-03-14T16:00:00.000Z to 2023-03-15T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-15T08:58:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:704 Chart loading state is AUTO_REFRESH
    http://192.168.31.54/ChartPro/ChartPro?cnlNums=3732&startDate=2023-02-13&period=17
    only this
    Chart loading state is COMPLETE
    http://192.168.31.54/ChartPro/ChartPro?cnlNums=3732&startDate=2023-02-13&period=35
    Time offset is 2023-02-13T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-13T16:00:00.000Z to 2023-02-14T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-14T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-14T16:00:00.000Z to 2023-02-15T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-15T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:534 Chart data received from 2023-02-15T16:00:00.000Z to 2023-02-16T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-02-16T16:00:00.000Z
    chartpro-form.js?v=3p-QFOM02FjUhri3jn_LZk_5yXFyPXbclVwGmTrSEPE:696 Time offset is 2023-03-15T09:01:00.000Z
    grhsc
    I’ll continue to follow your request, but before I do, I’ll share what I just checked.
    Is this info useful for analysis?
    I tried manually modifying the date in the URL to check the curve
    Normally, it can only show data for 1 month, such as now it is 2-16 to 3-15
    startDate=2023-02-15&period=28
    When I modify the date to 2-15, like the previous bug, it can only show that the data this 02-15, after 2-15 is blank
    startDate=2023-02-15&period=29
    The data is fully displayed
    startDate=2023-02-13&period=31
    Continue to move forward, startDate=2023-02-12&period=32
    Only data from the 02-12 can be displayed, after 2-12 is blank
    I changed other curves, and it can only reach 2-12. No matter how I adjust the value of period, I even use period=100
    grhsc
    Sorry, the second one still won’t open and I can’t edit.
    This is the info from the console after Press F12
    https://drive.google.com/file/d/1c83QS0zZ650iKjTgx_S6bLhC9CQ-OMIV/view?usp=share_link
    grhsc
    hello
    This is correct (1 month, February 16 to March 15)
    https://drive.google.com/file/d/1KHTR8rFeyuiCX_Jbzmy2gMQAirVHaTus/view?usp=share_link
    This is wrong (some days more than 1 month ago, Feb 13 to Feb 19)
    https://drive.google.com/file/d/1DmG6YpFFpAjkCFsQXQ3yYsh_EKQqzw4Q/view?usp=share_link
    https://drive.google.com/file/d/1FI–1IkX0FaTQVx85_h7Fam17sUn0lvj/view?usp=share_link
    Let me know if it’s not what you expected. I’ll find what you need again
    in reply to: SCADA-related services cannot be automatic started #12105
    grhsc
    Thank you so much for your continued attention. Attach the log information after its execution
    I have tried other ways. If I change the service startup type from automatic to automatic (delayed) startup, the 3 services of rapidSCADA can start normally.
    I don’t know why there is no need to set the delay in win 10 desktop version but it needs to be set in win server 2022.
    do you have encountered such a case before?
    If I find out why in the future, I’ll come back and note it here too.
    2023-02-10 22:16:09 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Server 6.0.0.1 started
    2023-02-10 22:16:09 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Storage FileStorage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2023-02-10 22:16:09 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Start logic processing
    2023-02-10 22:16:10 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] The configuration database has been read successfully
    2023-02-10 22:16:10 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][INF] Number of active channels for archiving: 3174
    2023-02-10 22:16:10 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][INF] Number of active channels for sending commands: 0
    2023-02-10 22:16:10 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Compile the source code of scripts and formulas
    2023-02-10 22:16:11 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Added the following dependencies:
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.12\netstandard.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.12\System.Console.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.12\System.Linq.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.12\System.Private.CoreLib.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.12\System.Runtime.dll
        C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll
        C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll
    2023-02-10 22:16:13 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] The source code of scripts and formulas has been compiled successfully
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Module ModArcBasic 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Module ModArcPostgreSql 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Archive Cur initialized successfully
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Archive Min initialized successfully
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Archive Hour initialized successfully
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Archive Events initialized successfully
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Start listener on port 10000
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Delete outdated data from the Min archive older than 10/02/2022
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Delete outdated data from the Hour archive older than 10/02/2022
    2023-02-10 22:16:14 [TEST-RENHUA-RAP][TEST-RENHUA-RAP$][ACT] Delete outdated data from the Events archive older than 10/02/2022
    • This reply was modified 3 years, 9 months ago by Mikhail.
    in reply to: SCADA-related services cannot be automatic started #12095
    grhsc
    here they are, by the way, I see from the forum timestamp that your local time is too late, It’s not urgent, you can help me when you are free, take care!
    C:\Program Files\SCADA\ScadaServer>ScadaServerWkr.exe
    info: Scada.Server.Wkr.Worker[0]
    Server is started successfully
    info: Microsoft.Hosting.Lifetime[0]
    Application started. Press Ctrl+C to shut down.
    Hosting environment: Production
    Content root path: C:\Program Files\SCADA\ScadaServer
    Application is shutting down…
    Server is stopped
    • This reply was modified 3 years, 9 months ago by grhsc.
