quintelosky
ParticipantHi
I solved it.
In “…\Instances\Default\ScadaComm\Config\DrvOpcUa.View.xml”
Change:
<!– WARNING: SHA1 signed certficates are by default rejected and should be phased out.–>
<RejectSHA1SignedCertificates>false</RejectSHA1SignedCertificates>
<MinimumCertificateKeySize>1024</MinimumCertificateKeySize>Now works fine
quintelosky
ParticipantMany thanks Mikhail
quintelosky
ParticipantOk, I will check it
Many thanks
quintelosky
Participantquintelosky
ParticipantHi
Ok, I tried with the example and don’t work
I copied and pasted the same (you can view the path in the image), put in popup->viewid 12 and nothing. I tried with all paths combinations but don’t work. The project is in other path, like c:\scada\projects, and the rapidscada is in c:\program files\
Can you do a simple test with your rapidscada?
quintelosky
ParticipantHi
Ok, I edited modal.js to make tests and I can change to extra large, but the scheme compiler only accept small, normal and large
Well, I modified modal.js and I’m using small to extra large (if you put small popup, you will view extra large popup)
quintelosky
ParticipantHi
I use rapid 6. For example 1200×700
I readed that bootstrap have Extra large size, Is it possible (activate this option in rapid 6)?
quintelosky
ParticipantHi
I tried it but didn’t work
Many thanks
quintelosky
ParticipantOk, solved
It was a problem with s7-1200 (it have a limit)
quintelosky
ParticipantHi
Ok. Yes, I know, in fact, if you remember, you helped me to solve a problem with opc ua server (s7-1500).
Can you give me some tips to create a kp for that? Only some tips
Many thanks
quintelosky
ParticipantHi
Yes, I know that I can do that. But, I have some programas that centralize the communications.
For example, I have a program that connect with +50 stations via modbus tcp, modbus radio, modbus serie. Works fine, and I don’t want change it (if something works don’t change it). And I have other program (api in vb) that communicate with a server to obtain values from Microcom hardware (via Zeus web server). And my Intouch obtain values with DDE from all.
For me, is more simple mantain all programs and ask via dde.How can I create a kp for that? (my knowledge is limited)
Many thanks
quintelosky
ParticipantHi Mikhail
For the moment works fine. Now I’m making the scada using the opc ua and I can read/write values without problems.
Good job
quintelosky
ParticipantHi
Ok, was a windows problem with protection. Now is working
I need do some tests
Perfect, you are the best
quintelosky
ParticipantSorry. I have a problem with the new dll
quintelosky
ParticipantFor example with:
“DB 16 SeƱales analogicas”.”TurbidezEntrada”.”MaxEscalat”
I need read the value and change the value, but datatype is float and yesterday I cant modify the vale
Thanks -
