DDE Communicator
Forum Home › Forums › Communicating with Devices › DDE Communicator
  • #10095
    quintelosky
    Hi
    Is it possible to communicate using DDE with an application?
    Now, I have an application (with Wonderware Intouch) that interrogates my plcs via modbus tcp, and my Intouch obtain these values (associated with a tag ) via DDE.
    or, Is it possible create a Kp for that?
    #10096
    Krzysztof
    It’s possible to creaate Kp, but can’t you poll the PLC in RapidScada for Modbus TCP? PLC should support multimaster over tcp/ip
    #10097
    Agree with the above. It’s possible to poll a Modbus TCP device by Rapid SCADA independently.
    #10098
    quintelosky
    Hi
    Yes, I know that I can do that. But, I have some programas that centralize the communications.
    For example, I have a program that connect with +50 stations via modbus tcp, modbus radio, modbus serie. Works fine, and I don’t want change it (if something works don’t change it). And I have other program (api in vb) that communicate with a server to obtain values from Microcom hardware (via Zeus web server). And my Intouch obtain values with DDE from all.
    For me, is more simple mantain all programs and ask via dde.
    How can I create a kp for that? (my knowledge is limited)
    Many thanks
    #10099
    DDE is not supported. You could use OPC UA in the same manner, a popular standard for industrial automation.
    #10100
    quintelosky
    Hi
    Ok. Yes, I know, in fact, if you remember, you helped me to solve a problem with opc ua server (s7-1500).
    Can you give me some tips to create a kp for that? Only some tips
    Many thanks
    #10101
    May be you should create a driver for Rapid SCADA v6 beta instead of v5.
