kcks66
ParticipantHi Mikhail,
I got the result in Minute archive as shown below:
I see every 30 minutes got data as expected. Somehow there is always 0 if out of HH:00:00 and HH:30:00. Is ModDiffCalculator working like this?
The other part is data channel 102 always 0 in the Table, as below:
Since the Channel 102 always show 0 I couldn’t use to attach to a Dynamic Text in Scheme as well as use as source channel for another calculated channel to further formula function.
Pls advice for my ModDiffCalculator configuration:
kcks66
ParticipantI should select custom period then is ok.
<ModDiffCalculator>
<GeneralOptions>
<CmdCode />
</GeneralOptions>
<Groups>
<Group active=”true” name=”30 Minutes” periodType=”Custom” customPeriod=”00:30:00″ offset=”00:00:00″ delay=”10″ archiveBit=”1″>
<Item srcCnlNum=”101″ destCnlNum=”102″ />
</Group>
</Groups>
</ModDiffCalculator>kcks66
I configured custom period to 00:30:00. Somehow after I saved and upload to server the custom period became 00:00:00. I tried many times the custom period looks like always reset to 00:00:00.
<ModDiffCalculator>
<GeneralOptions>
<CmdCode />
</GeneralOptions>
<Groups>
<Group active=”true” name=”30 Minutes” periodType=”Minute” offset=”00:00:00″ delay=”10″ archiveBit=”1″>
</Group>
</Groups>
</ModDiffCalculator>The module log:
I checked result from excel is the different calculation is based on 1 minute.
Pls advice and thank you.
kcks66
Noted. Going to give it a try. Thanks.
kcks66
I have one question; example if there is no data/data lost (channel 101) before 9:00:00 PM but resume back before 9:30:00 PM, what happen to the ModDiffCalculator module to calculate (channel 102) at 9:30:00 PM?
Channel 102 (9:30:00 PM, data?) = Channel 101 (9:30:00 PM, got data) – Channel 101 (9:00:00 PM, no data)
kcks66
My mistake; I thought Rapid SCADA will automatically create the rapid_scada database in PostgreSQL.
I manually create the rapid_scada database and everything works as expected.
kcks66
I installed v6 in a different PC this round and tried to use PostgreSql as my main achieve again.
However I am facing error in this PC, error log as below:
FYI, this PC is administrator password protected.
Pls advice and thank you.kcks66
I just enable the Current Data’s detailed log. Rigth now I just wait for next Current Data suddenly become Not Ready again in the future, right?
kcks66
My archive configuration screenshot as below.
But I have no idea where to get the archive log file.
This reply was modified 2 years, 8 months ago by
kcks66.
kcks66
Noted. I try calculate power consumption by using current data at the moment.
Thank you.kcks66
I have Elastic Report but what I want to do is to use the result/value from the calculated channel (e.g., power consumption) to show in table and to plot on chart.
kcks66
Let say I have a Real Channel (101) to read meter energy kWh data, I configure a Calculated Channel (102) to calculate how much energy used in 30 minutes. In my script when every 30 minutes interval time, I will take the Real Channel (101)’s Current reading and access PostgreSql Minute Archive database to search for the same Channel (101) but DateTime is past 30 minutes ago to get its value. Thus I can get their different to become the result.
kcks66
Right now I have weeks of data in Postgresql database. I am thinking of write a script in Formula to pull past DateTime Cnl channel’s Val value from database for further processing in real-time.
Can I do that? Pls advice and thank you.
kcks66
I configured PostgreSql as my main achieve now. This is great.
Thank you.kcks66
Noted. Looks like I shall get used to the method:
“click and hold a left mouse button, then move the mouse to select the required period of time”
