kcks66
ParticipantHi Mikhail,
I retry many times by using the Server Generator. But no new file is created. Pls advice and thank you.
This reply was modified 5 years, 9 months ago by
kcks66.
kcks66
I have new question to ask; can I generate value into new DAT file with date earlier than recorded?
I want to generate value into channels for date 2018 Jan 1 as example.
Thank you.kcks66
It is worked after I changed the ChartGap to 4,000 sec.
https://ibb.co/R2LZXkBThank you.
kcks66
ParticipantHi Mikhail & manjey73,
I succeed generated value and show on Chart after Status wrote 2.
There were one value generated at 00:00 and another value generated at 01:00. Is there any possibility to join the line in between them?
kcks66
I tried to manual generate value into Archive Data, as below:
https://ibb.co/vXMytQhI can see the value is generated, as below:
https://ibb.co/8rfRVbzHowever, I cannot see from the Chart, as below:
https://ibb.co/VMVH7KnIs there anything I missed out? Pls advice and thank you.
kcks66
I could try the manual input one by one value method. Pls advice for how to do it?
kcks66
I am getting all the REAL channel type exported to MySQL. However, the OTHER THAN REAL channel types were not exported to MySQL.
Pls advice for how shall I configure the other channels types in highlighted?
Thank you.kcks66
Rapid SCADA can access MySQL now. Thank you.
I manually overwrite the “password”, and it worked.
kcks66
I think I shall wait for Rapid SCADA 6 in the next year.
Thank you.kcks66
It is worked fine now. Thank you.
Now I am further explore the way for an user to key in their comments/remarks on the events. Is there any way for this?
kcks66
Thanks for your correction. I got notifications already.
Now I am getting non-stop of notification from the same input channel, what should I configure to get just one time of the alarm high event?
kcks66
The chart is working well now after cleared browser cache.
Thank you.kcks66
I update Rapid SCADA to version 5.8.1. However, I still got error:
Application Error
Details:
The specified string is not array of integers.kcks66
My PC ScadaWebCommon.dll timestamp is 2020/1/28.
kcks66
ParticipantI have the similar problem. How to do webserver restart?
