kcks66
Viewing 15 posts - 136 through 150 (of 183 total)
  • in reply to: Sending Command Skipped #10066
    kcks66
    Hi manjey73 & Mikhail,
    I set to the channel status but I have no idea what to do next for the formula.
    https://ibb.co/VtCJpXN
    Pls advice and thank you.
    in reply to: Sending Command Skipped #10063
    kcks66
    Thanks for the explanation. I am able to trigger now.
    However, is there possibility to detect the ‘ — ‘ when the device is offline? Then send out email alert to inform recipient for such faulty.
    https://ibb.co/m5w8xSF
    in reply to: Run Rapid SCADA in Microsoft Azure VM #9679
    kcks66
    Hi Mikhail,
    Standard B2s (2 vcpus, 4 GiB memory) with add on 128GB HDD
    in reply to: Run Rapid SCADA in Microsoft Azure VM #9677
    kcks66
    Hi Mikhail,
    Thanks for your advice. I managed to setup Rapid SCADA runs in Microsoft Azure VM.
    in reply to: Rapid Gate #9626
    kcks66
    I created an new User with password at the target server. I filled the new User and Password in the Connection Options.
    Now my problem solve.
    in reply to: Rapid Gate #9622
    kcks66
    Hi Mikhail,
    I am testing the RapidGate too.
    Pls advice for what or how to do with the Username and Password?
    The log stated Incorrect Username or Password.
    https://ibb.co/hV1r60n
    My Connection Option setting for target Rapid SCADA (Username & Password untouch):
    https://ibb.co/F6C5c4p
    • This reply was modified 4 years, 11 months ago by kcks66.
    in reply to: Migrate plugin license key? #9532
    kcks66
    Hi Mikhail/manjey73,
    I am facing problem when I try to activate Automatic Control Module in my VM.
    The error message say:
    Error getting module interface type from the library ModAutoControl.dll: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
    I search following example to grant full trust as below:
    <configuration>
    <runtime>
    <loadFromRemoteSources enabled=”true”/>
    </runtime>
    </configuration>
    My question is what file and which lines of the file should I paste this code into? Thank you.
    in reply to: Migrate plugin license key? #9531
    kcks66
    Hi manjey73,
    I enable full control rights to the files and it worked. I can save my web configuration now.
    in reply to: Migrate plugin license key? #9529
    kcks66
    Hi Mikhail,
    I migrated Rapid SCADA 5.8.2 from Local PC with Windows 10 to Virtual Machine with Windows Server 2006.
    So far so good but I found out I had error when saving Web Configuration, as below:
    https://ibb.co/3r4DrHj
    Pls advice for is there any steps that I missed?
    in reply to: Migrate plugin license key? #9528
    kcks66
    Look’s like I have no choice to purchase new license keys then.
    Thanks for the reply.
    in reply to: Using PostgreSQL #9345
    kcks66
    Hi manjey73,
    Yes, it worked after I use version 5.8.3.
    in reply to: ChartPro export data in hourly #9082
    kcks66
    Hi Mikhail,
    I tried to play around with the Elastic Sample Report, is it at the TimeTime section type?
    <Section>
    <SectionOptions>
    <ID>Section1</ID>
    <SectionType>TimeTime</SectionType>
    <Subheading>Main Usage</Subheading>
    <SubheadingVisible>true</SubheadingVisible>
    <SkipFirstHour>false</SkipFirstHour>
    </SectionOptions>
    <Table>
    <DataItem cnlNum=”101″ calcType=”Val” calcTotal=”true” calcAvg=”true” calcMin=”true” calcMax=”true” colStyle=”col-xs” />
    </Table>
    </Section>
    in reply to: ChartPro export data in hourly #9081
    kcks66
    Hi Mikhail,
    That’s great. Looking forward to have this functionality.
    By the way, how to configure to have data in every hour?
    https://ibb.co/GTc0xYx
    in reply to: ChartPro export data in hourly #9075
    kcks66
    Hi Mikhail,
    Noted for the CharPro current design format.
    However, is there possibility to configure something like the Minute Data Report to become another option like Hour Data Report?
    https://ibb.co/y5L4fd0
    So I can add any desired channel and From-To date to export data every hourly?
    in reply to: Get data from excel into DAT files #8985
    kcks66
    Hi Mikhail,
    I forward the excel sample to your email.
