gasin
Participantok, i done as you suggest and now it’s work.
thanks.
gasin
ParticipantI install .NetFramework at first and then iis.
gasin
ParticipantYes, i try to remove all .Net framework 3.5 and 4.8 and iis setup on “Turn window on or off” then reinstall again. But problem still occur.
gasin
Participantyes, it has this file on C:\SCADA\ScadaWeb\
gasin
ParticipantThe result after open http://localhost/Scada/ClientApiSvc.svc
“This localhost page can’t be found
No webpage was found for the web address: http://localhost/Scada/ClientApiSvc.svc
HTTP ERROR 404”.gasin
Participanti try as you suggest but problem still occur.
i try to uninstall/reinstall iis and select same as your link detail but can solve problem.
Problem was the same. When i open webstation, it will show error both scheme and table pages.
i check my iis and see that it use asp.net 4.8. i don’t know is this a problem for this? I try to run aspnet_regiis.exe -i and it show “This option is not supported on this version of the operating system.”. i use window 10.
Any suggest for this problem.
here is my selection when install iis.
gasin
Participantnow, i’ve problem with autologin,too.
before i add autologin to scadaweb folder, everything work fine.
after i add autologin to scadaweb folder and try to access website via address http://localhost/scada/login.aspx , i can pass login padge but it show error like this
https://1drv.ms/u/s!Ah3lJWvSyxVOgvcCAlGYfk_y6Xc4IA
and when i try to access website to be autologin like this http://localhost/scada/autologin.aspx , it show error like this
https://1drv.ms/u/s!Ah3lJWvSyxVOgvcBOsJJntEUNlbZHw
so, how can i solve this. please suggest.
gasin
i try to do as your mention. after that i found error occur on screen. it show message error to update scheme data and i see all graphic did not show value.
it’s look like graphic can not connect to database.
how can i solve it?
gasin
i try to use this formula : Cnl > 0 ? Cnl : Val()
but the result is when i write to 0, input still show 1. and device connect normally.
gasin
Participanthere is error from server.
2019-05-14 20:02:34 <DESKTOP-1CTUDRI><SYSTEM><ERR> Error compiling the source code of the formulas
Line 742, column 58; error cs1501: No overload for method ‘if2’ takes 2 arguments
See the file c:\SCADA\ScadaServer\Log\CalcEngine.cs with the source code
2019-05-14 20:02:34 <DESKTOP-1CTUDRI><SYSTEM><ERR> Normal program execution is impossiblei’m create function “if2” with 3 inputs and got this error.
and here is my function.
public if2(double in1,double in2,double in3)
if(in1==0 && in2==1)
{in3=1;}
if(in2==0)
{in3=0}
return in3;
}in1 & in2 are input parameter from register via modbus and in3 is extra input that i create to database to get result from this function.
how can i solve it, please suggest.
