nelson.albarran
ParticipantI created the DbImport Device and I have communication with the data base, the query works. But I dont know how to exec the command, “exec my_sp”.
https://drive.google.com/open?id=1Lxf8O4YlVxKqWLpRQvc0mu6Mkl4gRrYH
nelson.albarran
ParticipantHow? I created a Output Channel, and i created the alarm in Automatic Control Module. What more i should do. Please, a quick guide.
nelson.albarran
ParticipantThe port is open, the log is:
2020-04-08 19:17:27 Communication session with the Device 51 “SNMP”, type: KpSnmp, call number: 192.168.60.205:161
Get variables of the group “Temp”
Error getting variables: error in response. NoSuchName. Index: 1. Errored Object ID: .1.3.6.1.4.1.232.6.2.6.8.1.4.0April 23, 2019 at 3:28 pm in reply to: Difference between current and previous data of same channel #5352nelson.albarran
ParticipantApril 22, 2019 at 3:30 pm in reply to: Difference between current and previous data of same channel #5346nelson.albarran
ParticipantApril 22, 2019 at 1:25 pm in reply to: Difference between current and previous data of same channel #5339nelson.albarran
ParticipantMy setting is
I have obtained always zero as result.
This reply was modified 7 years, 6 months ago by
nelson.albarran.
April 18, 2019 at 8:45 pm in reply to: Difference between current and previous data of same channel #5322nelson.albarran
ParticipantHi, I followed your advice, but I have not achieved to obtain the result that i wish.
Channel 1: The data of sensor. // SetVal(2,Cnl)
Channel 2:
Channel 3: Val(1)-Val(2)Wich is my error?
nelson.albarran
ParticipantThe problem is that myuser appears like disabled role.
nelson.albarran
ParticipantThe chart pro is ok, I can wiew the charts with other users (admin or guest), but not with my user. i dont know what happens
nelson.albarran
Participantok, Thanks
nelson.albarran
ParticipantI solved the problem thanks.
nelson.albarran
ParticipantThe connection is good usually, but when the connection is broken, the period of no-connection is around one day, maybe more. For this reason, we are very interest with the sync the data queue.
This reply was modified 7 years, 7 months ago by
nelson.albarran.
nelson.albarran
ParticipantThanks.
