Exec Stored Procedure of SQL Server
Forum Home Forums Understanding the Software Exec Stored Procedure of SQL Server
  • #6720
    nelson.albarran
    Hi, I want to exec a stored procedure by alarm using automatic control, Is it possible?
    • This topic was modified 6 years, 5 months ago by Mikhail.
    #6724
    Using Automatic Control Module you can send a command. KpDbImport driver helps to execute SQL according to the command.
    #6725
    nelson.albarran
    How? I created a Output Channel, and i created the alarm in Automatic Control Module. What more i should do. Please, a quick guide.
    #6726
    Fist of all, configure KpDbImport driver. The approach is usual. Create a device, input and output channels. Make sure that when you send a command via Administrator’s UI, the driver executes SQL request.
    You could provide screenshots of your KpDbImport settings if they don’t work.
    #6729
    nelson.albarran
    I created the DbImport Device and I have communication with the data base, the query works. But I dont know how to exec the command, “exec my_sp”.
    https://drive.google.com/open?id=1Lxf8O4YlVxKqWLpRQvc0mu6Mkl4gRrYH
    #6738
    The modern KpDbImport has the Commands tab to configure commands.
    You should update Rapid SCADA to 5.8.x
