Rapid Gate
  • #5165
    nelson.albarran
    Hi, I need to implement the following architecture. (Large System)
    http://doc.rapidscada.net/content/en/software-overview/software-architecture-files/scada_arc_en.png
    I understand that one possibility is to use Rapid Gate.
    How do I configure it to be able to have several Scada interconnected.
    How many licenses must be purchased.
    #5167
    If the server is one of the main, the Rapid Gate is not needed.
    If there are several servers plus one main server, then Rapid Gate is needed for each slave server and the corresponding number of licenses for each Rapid Gate is required.
    A large diagram is specified without Rapid Gate
    • This reply was modified 7 years, 7 months ago by manjey73.
    #5169
    Rapid Gate is needed for data exchange between many instances of Rapid SCADA. For example, big central instance and many small local instances. You need to install a Rapid Gate and get a license for each small local instance of Rapid SCADA.
    #5218
    nelson.albarran
    Thanks.
