leon
Viewing 12 posts - 31 through 42 (of 42 total)
  • in reply to: Responsive Web Design #3957
    leon
    Hi
    I put three buttons on the basemap.
    He is normal.
    https://imgur.com/a/tchy5rI
    Thanks!
    in reply to: log storage location #3956
    leon
    Hi Mikhail
    Is this correct?
    https://imgur.com/a/WqlC1cY
    Hi manjey73
    Thank!
    in reply to: log storage location #3949
    leon
    Main save DI/O AI/O logs.
    • This reply was modified 8 years, 3 months ago by leon.
    in reply to: Responsive Web Design #3946
    leon
    Hi
    Thank you for your example.
    Because buttons and displays are placed on the basemap.
    Basemaps need to be manually zoomed in or out on different devices and on different screens.
    in reply to: log storage location #3945
    leon
    Hi Participant
    Thank!
    Hi Mikhail
    Hope that all logs can be stored on an external hard drive because the SD card is easier to fault.
    in reply to: Some problems #3448
    leon
    Is it possible to send command to open web pages via RAPID SCADA?
    Received the door position(open/close) signal to the PLC
    By RAPID SCADA send command to the PC
    To open the web(ipcam monitor screen)
    https://imgur.com/a/57uuM
    Because I use a translator to talk to you
    Please bear with me Thank you!
    • This reply was modified 8 years, 6 months ago by leon.
    in reply to: Some problems #3433
    leon
    Can receive data from PLC (binary) send to PC(command: start chrome.exe http://192.168.1.1XX) to open web page?
    https://imgur.com/a/Nshgr
    3.
    Solved!
    in reply to: Some problems #3385
    leon
    Re-install scada_5.5.1 problem solved!
    2.
    Receive data from PLC (binary) such as gate position(open/close) to open ipcam web page.
    3.
    Use IP(mail server) with ScadaCommCtrl send mail.
    in reply to: Mail SMTP Set #3365
    leon
    hi
    I succeeded Thank you all!!
    Sending email notifications.
    Commands:
    1 (binary) – send the notification.
    Command text examples:
    group_name;subject;message
    contact_name;subject;message
    email;subject;message
    in reply to: Mail SMTP Set #3358
    leon
    hi
    Email has not been sent yet
    https://imgur.com/a/tDWns
    Thank you very very much for your answers
    in reply to: Mail SMTP Set #3340
    leon
    Hi Mikhail
    I’m sorry I don’t really use
    Is there a similar setting reference?
    Administrator>Devices>Call unmber need set email?
    Communicator>Line 4>Request Sequence>Call unmber and Command line need set??
    https://imgur.com/a/DSRDb
    in reply to: Mail SMTP Set #3337
    leon
    Joan
    Thank you for your reply but I’m still trying
