October 30, 2019 at 7:01 am in reply to: Schedule function and screen editing alignment function #6023
leon
ParticipantHI:
1.Hope to have a client settings interface,let users operate by themselves schedule.
2.Hope scada has alignment function.
https://imgur.com/a/WV6MKSdThanks!
leon
ParticipantHope can be achieved.
leon
ParticipantHI:
Now working normally, thank you!leon
ParticipantHi.
Please help me, thank you.leon
ParticipantHi
Can help check for errors? I provide project files.leon
Reinstall 5.5.3 shows normal.
5.6.0 preset project is normal.Currently not using the 5.6.0 build project.
leon
I tried web page reload(Ctrl+F5), still not improving.leon
ParticipantLooking forward to this feature.
leon
ParticipantHi Mikhail
The problem is solved,thank you very much for your teaching.leon
Thank you, I understand.
My approach is to create a channel, transfer it to the PLC comparison, and then display the result.Sorry, I don’t understand enough.
What I need is to modify the color of the event in the image.
https://imgur.com/a/ZjwHlKd
Because the channel is used alarm.
The event is green, may not be obvious enough.leon
I searched for the discussion but I still don’t understandHow to change the channel Lower alarm limit; lower limit; upper limit; upper alarm limit ,from the web interface.
If using two channels for comparison,How to do change the event color?
Alert is green, may not be obvious enough.leon
I understand, thank you.leon
Participantleon
Sorry, I am not clear enough.
Can I use different formulas for different buttons in the window where the command is sent?
They are all output channels (19).
https://imgur.com/a/K6Gfpt1
https://imgur.com/NGl3BMG-
This reply was modified 8 years, 2 months ago by
leon.
leon
ParticipantHi manjey73
Thank you for your hot reply. -
