Visual Devide Driver
Forum Home › Forums › Development and Integration › Visual Devide Driver
  • #13877
    Zeus
    Hi Mik,
    I am trying to develop a virtual device driver.
    Its functionality feels like Flash or Rom in PLC.
    Now I have encountered a problem.
    When I use the send command function to write a large amount of data to a virtual device, the session will be suspended.
    When I use writing curdata to a virtual device, if the frequency is low, the data will become 0.
    How can I develop virtual devices correctly and persist data correctly within them.
    #13880
    Hi Zeus,
    What amount of data you try to send using a command?
    Could you explain?
    #13881
    Zeus
    The first situation
    I use sendcommand sending about 30 commands to virtual device per second and the base session will be suspended. The session will wait until the cmd is handeld.
    The second situation
    I use the writcurdata method to send data to the server and persist the data to a dat file. When the line starts, read and assign the dat file to curdata.
    #13882
    Zeus
    I just want to persist the data to Scadaserver, treat it as a long-term valid data, and use it as a current value when reading it
    #13887
    If commands require heavy processing, implement a queue to process them in background.
    To analyze the issue, you should use a debugger or log files.
