v6- bit mask and create/update channels
Forum Home › Forums › Understanding the Software › Formulas › v6- bit mask and create/update channels
  • #12135
    asherb
    hello, I am currently working with rapid scada v6, I am running into one problem:
    I have Modbus TCP line and device connected and communicated, I have several holding registers in element group set up with bit mask. When i create channel and generated the channel, the server will be errored, i can see ‘ (389,48): error CS1503: Argument 1: cannot convert from ‘Scada.Data.Models.CnlData’ to ‘double’
    in the server log. However, if there is no bit mask for the holding registers, after I created the channel, the server will be normal and functional. Please advise what would be the potential issue.
    Also, I am wondering how I can update the channel if I add more registers in element group later on? is adding them one-by-one the only way to do it?
    thanks
    #12138
    Thank for the issue report. It’s important.
    The Bit mask checkbox of a Modbus element does not affect how device is polled, but it affects generating channels based on the Modbus template. Probably, there is an error in channel formula. I will check and write back (next week).
    The channel wizard can add new channels. It does not update the existing channels. In a preview window, remove the unnecessary channels and add only channels for new registers.
    #12145
    To fix this error, open your project in Administrator, open the Scripts table and add a new row containing the function:
    public double SetBit(CnlData cnlData, int n, double isOn)
        return cnlData.Stat > 0
            ? SetBit(cnlData.Val, n, isOn)
            : double.NaN;
    The fix will be included in the next Rapid SCADA release.
    #12147
    asherb
    error fix, thanks Mikhail!
    #12150
    Thanks for finding this!
