Small individual Bar Graphs for different set of range and colour
Forum Home › Forums › New Ideas › Small individual Bar Graphs for different set of range and colour
  • #2132
    Kurlekar
    I would like to represent different Temperature and Pressure valves on Bar graphs around 8 to to 10 readings on one page, I should able to select the colour of bar line, and could able to change the colour of bar line if it exceeds to expected limit.
    Does any one has got example, please share.
    #2134
    I have no ready to use example. To add progress bar control an a scheme you should create a set of images, for example, for 0%, 10%, … 100% of value. Use these images in Dynamic Picture element. Color can be set according to status of input channel. Currently you can’t set the fill color of a bar, but you can change a border color. Set border color property to Status.
    The new scheme engine is under development. We are planning to implement the feature you need.
    #2136
    Kurlekar
    Okay, Thanks, I can use only numerical value at present and I will wait for next upgrade.
    When we can expect to release next upgrade?
    #2138
    This is a major task, but release date depends on project load. Usually we fix dates only for commercial orders related to Rapid SCADA.
    Follow us on Facebook to receive notifications.
    • This reply was modified 9 years, 5 months ago by Mikhail.
