setting output channel value on the base of data received
Forum Home Forums Understanding the Software setting output channel value on the base of data received
  • #8644
    afzal
    Hi
    i would like to know is it possible to implement following logic
    if inputchannel 201 value <800;
    wait 5 seconds
    write modbus value 3100 to output channel 801
    wait 5 seconds
    check if inputchannel 201 value==800
    set modbus value to 3100
    can you please help me, how to develop the formula?
    should i implement it in input channel or output channel ?
    Afzal
    #8646
    afzal
    i am using this formula
    if (Val(110)<800)
    SetVal(801, 32);
    but it’s not working.
    input channel is 110
    output channel is 801, value is 32.
    i want to read input channel value and want to set the value of output channel.
    inbetween these 2 commands i want to put some delay.
    can you please help me out ?
    #8652
    Definitely, you need Automatic Control Module. Even with the module it may be tricky.
      The idea is the following (using the module):
    1. Create a trigger that detects “inputchannel 201 value < 800"
    2. Send a command with 5s delay to “write modbus value 3100 to output channel 801”
    3. Send a command with 10s delay to “set modbus value to 3100”
    4. In the output channel formula for the 2nd command, check the required condition “inputchannel 201 value==800”
    In case of questions during implementation, post screenshots and description in this topic.
