Forum Home › Forums › Runtime Bugs › Server Bugs › Server disconnecting missing
- This topic has 2 replies, 2 voices, and was last updated 5 years, 7 months ago by
Artos9.
April 9, 2021 at 10:23 am #8690
Artos9
ParticipantHello,
I’m working about Rapid Scada Integration with using ServerComm class in source code.I had an issue with disconnecting with Scada Server only on Linux.
Process is:
1. Create comm settings.CommSettings settings = new CommSettings("localhost", 10000, "ScadaServerCtrl", "12345", 10000); Log log = new Log(Log.Formats.Full);2. Creating connection and data instance
ServerComm serverComm = new ServerComm(settings,log); SrezTableLight.Srez curSrez = new SrezTableLight.Srez(datetime,tab);3. Fill data and SendArchive
curSrez.SetCnlData(mapping[j].channel_num,prob[j]); bool dataSent = serverComm.SendArchive(curSrez, out res);4. Close connection
serverComm.Close();ScadaServerSvc.log shows log only connected and authorized logs:
2021-04-09 11:58:08 <kroll-VirtualBox><root><ACT> ScadaServerService 5.1.4.0 is started
2021-04-09 11:58:08 <kroll-VirtualBox><root><ACT> Module is loaded from the file /opt/scada/ScadaServer/Mod/ModAutoControl.dll
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Module is loaded from the file /opt/scada/ScadaServer/Mod/ModDBExport.dll
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Check the existence of the data directories is completed successfully
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Check the existence of the configuration database files is completed successfully
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Input channels are read from the configuration database. Active channel count: 211
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Ouput channels are read from the configuration database
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Users are read from the configuration database
2021-04-09 11:58:09 <kroll-VirtualBox><root><ACT> Formulas are read from the configuration database
2021-04-09 11:58:11 <kroll-VirtualBox><root><ACT> The formulas source code has been compiled
2021-04-09 11:58:11 <kroll-VirtualBox><root><ACT> Connection listener is started
2021-04-09 11:58:11 <kroll-VirtualBox><root><ACT> Start server
2021-04-09 11:58:11 <kroll-VirtualBox><root><ACT> Current data are not loaded
2021-04-09 11:58:20 <kroll-VirtualBox><root><ACT> Connect to client 127.0.0.1
2021-04-09 11:58:20 <kroll-VirtualBox><root><ACT> The user ScadaComm is successfully authenticated
2021-04-09 12:07:00 <kroll-VirtualBox><root><ACT> Connect to client 127.0.0.1
2021-04-09 12:07:00 <kroll-VirtualBox><root><ACT> The user ScadaServerCtrl is successfully authenticated
2021-04-09 12:07:00 <kroll-VirtualBox><root><ACT> Connect to client 127.0.0.1Finally after near 1000 opened connections I can see exception in code:
Error receiving data: Error connecting to SCADA-Server: Unable to read data from the transport connection: Operation on non-blocking socket would block.Do you have some solutions?
Thanks you.
This topic was modified 5 years, 7 months ago by
Artos9.
April 9, 2021 at 1:16 pm #8697
Probably 1000 connections is too many for Mono .NET framework. As I remember, an OS has a limit of open connections. It’s possible to find a command to change this limit.
For what reason do you need so many connections?April 26, 2021 at 12:51 pm #8817 -
