Sending SetVal() from Schema
Forum Home Forums Understanding the Software Sending SetVal() from Schema
  • #17021
    rapidscadaaks
    Hi
    Please guide on steps for changing Channel value of a Calculated Chanel using using Rapid Scada Schema.
    For e.g. Channel 101 is a calculated channel with formula SetVal(101,1) which returns ‘0’ as the Channel Value. How to change it to 1 using Schema ?
    • This topic was modified 12 months ago by Mikhail.
    #17032
    Could you describe your task more common? Do you need a channel that is changed manually?
    #17037
    rapidscadaaks
    Hi Mikhail
    I actually have 2 tasks :
    1. First is when sending command to a device using output channel to change colout of LED in Schema
    2. Second is to enter value of a calculated / input using Schema. Since this cannot be done directly, value for the input channel is to be updated to a output channel which is not connected to any device which in turn updates an input / calculated channel.
    I hope my above explanation is adequate
    #17050
    Try creating a channel of the Calculated/output type having an output formula SetData()
    It should help to change channel value according to user input.
    #17057
    rapidscadaaks
    Hi Mikhail,
    This works.
    Thanks for the help.
