Scala of rapid scada
Forum Home › Forums › Communicating with Devices › Modbus › Scala of rapid scada
  • #3189
    catcute
    I wonder Rapidscada can handle 10000 modbus devices(1000 independence modbus network segment) and get data every second? Can we setting communication with devices in paparalle or serial. And can we logging 100000 records per second to database using database export module?
    Thank you!
    #3190
    One instance of Rapid SCADA supports max. 65535 input channels. If you need more channels, deploy more instances of Rapid SCADA.
    The devices can be polled in parallel. You should play with sequential and parallel polling to achieve required performance.
    Tested interval of storing data into the archive is 30 seconds. You can set saving interval to 1 second, but it requires additional testing.
    Are you sure that your network equipment can provide the required data flow.
    #3193
    catcute
    Thanks Mikhail, I will check the data logging interval.
