– In Common Parameters what is the behavior of Domain controller and the check box?
– Archivedat and archivedatcopy are the same files, it’s for more security ? Maybe is usefull if I put archyvedatcopy folder in another server?
1. You can authenticate users of Active Directory (AD). In this case you don’t need to add users by SCADA-Administrator. It is easy to administrate and more secure. In AD the following global security groups have to be created:
ScadaApp
ScadaAdmin
ScadaDispatcher
ScadaGuest
ScadaDisabled
If a domain user is a member of the security group, he can login Rapid SCADA.
Domain controller is a server where AD operates.
2. It works like mirroring. It is recommended to save data copy to another HDD of the same server. In case of copying to another server it’s better to use a backup script or 3rd party backup tools becase network lags may affect SCADA-Server normal work.
