Rapid Scada Fail Over
Forum Home Forums Understanding the Software Rapid Scada Fail Over
  • #1938
    Sven
    Hi Mikhail
    Is it possible to setup a type of fail over system for rapid Scada. For example if I have rapid scada on two machines, a primary and secondary, if the primary fails then a switch over is made to the secondary, is it possible to be setup in such a way that the same data is show on both rapid scadas?
    #1939
    There can be different approaches:
    1. Use Modbus TCP devices that support more than one connections in parallel. You run 2 similar instances of Rapid SCADA, which receive the same data. Both the instances are active simultaneously.
    2. You can use the new module Rapid Gate which pass data from one Rapid SCADA instance to another in real time.
    But when the primary server stops, you have to somehow switch device polling to Communicator on another server. For example, stop the 1st Communicator service and start the 2nd Communicator service. May be it is possible to do it automatically by some condition.
    The important thing is a scheme of connection with devices.
    #1940
    Could you describe your system?
