I have connected Rapid SCADA with the OPC server and created communication lines.
I have the following classifications of tags under the same OPC server,
1)Analog Input
2)Analog Variables
3)Analog output
4)Digital Input
5)Digital Variables
6)Digital output
So, I created 6 separate communication lines connecting with the Same OPC server.
Rapid SCADA initially red all the values and was working fine. After some time rapid SCADA not communicating with the server and under Line stats its not showing the values?
