MQTT – Rapid scada
Forum Home Forums Communicating with Devices MQTT – Rapid scada
  • #6028
    hauvysieu
    Hello everybody! I’m called Sieu (22yo) and I come from Vietnam.
    I’m doing a project about Arduino – Rapid scada – PLC. That means I use sensor DHT11 to give signal to ESP32 and then it gives data of temperature and humidity to Rapid scada, the protocol that ESP32 connects to Rapid is MQTT. I’m in stuck because of the protocol MQTT to Rapid scada. So I really need advices from you. My English is not good so I’m sorry for that inconveniences.
    Thanks for reading! Hope to see your comments!
    #6029
    greenfoxx
    Hi!
    For undestanding, Can you please draw a diagram of the project?
    Could you please clarify, do you receive data from ESP32 in Rapid SCADA?
    The MQTT driver can both read and write data.
    • This reply was modified 6 years, 9 months ago by greenfoxx.
