Modify table XML “Minute data report”
Forum Home Forums Understanding the Software Modify table XML “Minute data report”
Viewing 12 posts - 1 through 12 (of 12 total)
  • #13602
    XptoPT
    Good morning,
    In the XML file created through “Report” in the “Minute data report” function, how can I change the template so that the date and time appears in the “Time” column in all lines?
    • This topic was modified 2 years, 8 months ago by Mikhail.
    #13605
    #13612
    XptoPT
    Good morning,
    I use version 5.8.4.
    I would like to take this opportunity to ask a new question, for new client projects, is it a good option to use this version?
    Or for new projects should we use version 6.1.5?
    I ask this question to find out if version 5 will continue to be updated or if for new projects we have to use version 6.
    Thanks.
    #13625
    I recommend Rapid SCADA 6.x, because it is more powerful and easy to configure.
    The report template was updated in v6. You could check it.
    #13626
    All new updates are made for v6.
    We will deprecate v5 when all documentation will be updated to v6.
    #13630
    XptoPT
    Good morning,
    “The report template was updated in v6. You could check it.”
    In version Rapid SCADA 6.x, “Report” in the “Minute data report” function appears the “Time” column in all lines?
    Thanks.
    #13631
    XptoPT
    Good morning,
    Considering your instructions, I am already working on version 6.
    Screenshot:
    https://ibb.co/vQcC4g0
    I can’t select any object to download the report.
    What configuration might be missing?
    Thanks.
    #13633
    Do you login as “admin”?
    Make sure that an object exists in the Objects table, and channel’s object is not empty.
    #13634
    Is it HelloWorld project?
    #13639
    XptoPT
    It’s a new project that I’m creating.
    Yes, I am logged in as “admin”.
    “Make sure that an object exists in the Objects table, and channel’s object is not empty.”
    Yes, I believe everything is correct.
    #13640
    Try the HelloWorld project located in SCADA\ProjectSamples\HelloWorld
    #13699
    XptoPT
    Thank you, I already discovered the problem.
