Modbus Serial Config Forum Home › Forums › Communicating with Devices › Modbus › Modbus Serial Config Tagged: ascii, modbus. serial. rtu This topic has 1 reply, 2 voices, and was last updated 7 years, 2 months ago by Mikhail. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts August 9, 2019 at 8:11 pm #5824 h2oilParticipant On new version, when trying to see stats of Device “x” it takes me to device “x” stats for example Email, OPC instead of for the actual device. Also is float32 available as config for communicator decode of data? August 10, 2019 at 8:58 am #5827 MikhailModerator it takes me to device “x” stats for example Email, OPC instead of for the actual device. Likely log files was not updated. After you upload configuration, check status of the Server and Communicator applications. is float32 available as config for communicator decode of data? If you ask about Modbus, yes. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
