M-Bus Protocol driver
Forum Home › Forums › Development and Integration › M-Bus Protocol driver
  • #4519
    Actually beta version of the driver is here
    https://drive.google.com/open?id=1w-aiHB-FluK8WTvhGYDv6STtGpSMtslk
    Driver paid. At the moment, you can only configure the driver manually.
    Since I have only two devices (and as luck would have both transmit the same type of Telegram), the driver supports only a Variable block of data without text and other variables of arbitrary length.
    The archive is a description of the settings in the configuration file with two working example for the Weser HeatMeter heat meter and electricity meter Eastron SDM220 and SDM230.
    • This topic was modified 7 years, 12 months ago by Mikhail.
    #4524
    It would be good, if you describe pricing options.
    #4526
    The cost of$ 30 or 50% discount when providing logs devices
    Driver_Mbus
