Forum Home › Forums › Communicating with Devices › OPC › KepwareEx rejects with error “Certificate doesn’t meet … requirement”
- This topic has 7 replies, 2 voices, and was last updated 2 years, 4 months ago by
zzz.
June 1, 2024 at 6:03 am #14591
zzz
Participanthttps://github.com/OPCFoundation/UA-.NETStandard/issues/305
@cxd110 Sha1 signed certs and 1k key length are by default deprecated.
June 1, 2024 at 6:29 am #14592zzz
ParticipantOpc.Ua.ServiceResultException: Certificate doesn’t meet minimum key length requirement. (1024<2048)
—> Opc.Ua.ServiceResultException: Certificate doesn’t meet minimum key length requirement. (1024<2048)
at Opc.Ua.CertificateValidator.Validate(X509Certificate2Collection chain, ConfiguredEndpoint endpoint)
at Opc.Ua.CertificateValidator.Validate(X509Certificate2Collection chain)
at Opc.Ua.Client.Session.Open(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`
1 preferredLocales, Boolean checkDomain)
at Opc.Ua.Client.Session.Create(ApplicationConfiguration configuration, ITransportWaitingConnection connection, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales)
at Scada.Comm.Drivers.DrvOpcUa.OpcClientHelperBase.ConnectAsync() in scada-v6/ScadaComm/OpenDrivers/DrvOpcUa.Common/OpcClientHelperBase.cs:line 198
at Scada.Comm.Drivers.DrvOpcUa.View.Forms.FrmDeviceConfig.ConnectToOpcServer()June 1, 2024 at 6:54 am #14595zzz
ParticipantHi Mik, if it is the other way around please help update the post title. And please shed light on how to workaround this check. Thanks.
I do everything to avoid laying hands on that OPC server again since an old system’s client it served also use OPC UA and is very quirky. No more incidents from me.
June 1, 2024 at 7:32 am #14596zzz
ParticipantBased on info from previous github issue link, I tried to disable it without success. I am not sure what did I miss ?
// OpenDrivers/DrvOpcUa.Common/OpcClientHelperBase.cs ... using (Stream stream = ReadConfiguration()) { config = await application.LoadApplicationConfiguration(stream, false); Console.WriteLine("RejectSHA1SignedCertificates = {0}", config.SecurityConfiguration.RejectSHA1SignedCertificates); config.SecurityConfiguration.RejectSHA1SignedCertificates = false; config.SecurityConfiguration.MinimumCertificateKeySize = 1024; } ... // create session EndpointConfiguration endpointConfiguration = EndpointConfiguration.Create(config); ConfiguredEndpoint endpoint = new(null, selectedEndpoint, endpointConfiguration); UserIdentity userIdentity = connectionOptions.AuthenticationMode == AuthenticationMode.Username ? new UserIdentity(connectionOptions.Username, connectionOptions.Password) : new UserIdentity(new AnonymousIdentityToken()); Console.WriteLine("Before OpcSession Create"); Console.WriteLine("RejectSHA1SignedCertificates = {0}", config.SecurityConfiguration.RejectSHA1SignedCertificates); Console.WriteLine("MinimumCertificateKeySize = {0}", config.SecurityConfiguration.MinimumCertificateKeySize); OpcSession = await Session.Create(config, endpoint, false, GetSessionName(), (uint)config.ClientConfiguration.DefaultSessionTimeout, userIdentity, null); log.WriteLine(Locale.IsRussian ? "OPC-сессия создана успешно" : "OPC session created successfully");RejectSHA1SignedCertificates = True
RejectSHA1SignedCertificates = False
====ERROR===
at Opc.Ua.Client.Session.Open(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain)
====END OF ERROR===-
This reply was modified 2 years, 4 months ago by
zzz.
June 1, 2024 at 7:50 am #14598zzz
ParticipantOK, I found the settings in config
Project\Instances\Default\ScadaComm\Config\DrvOpcUa.View.xml
Setting the above setting respectively, solves this error.But its strange override the config in config property gives no effect. 🙁
This is now solved, please help update the title. “Legacy server get rejected by RS6”
Now am getting new error.
Opc.Ua.ServiceResultException: Error establishing a connection: Error received from remote host:
Will start new post if turns out to persist.
June 2, 2024 at 7:16 am #14605zzz
ParticipantThis is not working on the server side, since the changes in
DrvOpcUa.View.xmlonly affects the client side, and when uploaded to ScadaComm, its loading OpcUa configs fromDrvOpcUa.Logic.xml.June 3, 2024 at 7:58 am #14612
MikhailModeratorYou should add DrvOpcUa.Logic.xml into the Rapid SCADA project, edit the file as needed, and upload the project for execution.
What parameter in DrvOpcUa.*.xml should be updated to fix the connection issue?June 13, 2024 at 7:28 am #14675zzz
ParticipantYes, make changes in
$Project\Instances\Default\ScadaComm\Config\DrvOpcUa.View.xml, once it works ok in ScadaAdmin OpcUA View, duplicate that xml asDrvOpcUa.Logic.xmlin the same folder and upload, Communicator shall take the same OpcUA setting.The change is the addition of the following two settings, as was stated in link in the first post:
<SecurityConfiguration> ... <!-- Re-enable SHA-1024 for old server --> <RejectSHA1SignedCertificates>false</RejectSHA1SignedCertificates> <MinimumCertificateKeySize>1024</MinimumCertificateKeySize> ... </SecurityConfiguration>-
zzz.
