KepwareEx rejects RS6 cert
Forum Home Forums Communicating with Devices OPC KepwareEx rejects RS6 cert
  • #14601
    zzz
    OK, this post is the genuine server rejects rapidscada post.
    ====ERROR===
    Opc.Ua.ServiceResultException: Error establishing a connection: Error received from remote host:
    at Opc.Ua.Bindings.ChannelAsyncOperation`1.End(Int32 timeout, Boolean throwOnError)
    at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.SendRequest(IServiceRequest request)
    at Opc.Ua.SessionClient.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
    at Opc.Ua.Client.Session.Open(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain)
    at Opc.Ua.Client.Session.Create(ApplicationConfiguration configuration, ITransportWaitingConnection connection, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales)
    at Scada.Comm.Drivers.DrvOpcUa.OpcClientHelperBase.ConnectAsync()
    at Scada.Comm.Drivers.DrvOpcUa.View.Forms.FrmDeviceConfig.ConnectToOpcServer()
    ====END OF ERROR===
    In the meanwhile
    Date Time Level Source Event
    2024-06-01 19:50:22 Error UA Server UaServer_EndpointCallback: SecureChannel 0 open failed! [status=0x80120000]
    According to this
    https://github.com/OPCFoundation/UA-.NETStandard/blob/3ba3b17237ef5f9364f0fd2ed276abfac266d42c/Stack/Opc.Ua.Core/Types/Generated/Opc.Ua.StatusCodes.cs#L145
    /// <summary>
    /// The certificate provided as a parameter is not valid.
    /// </summary>
    public const uint BadCertificateInvalid = 0x80120000;
    This is compatibility issue with the legacy OPC server (in this case kepwareex 5). I am giving up for this for now, it just took too much time.
    Mik, if you have any fix for compatibility like this, I’d like to have a try later. I think it may be the same key length issue the other way around (no bigger than 1024bit key).
    • This topic was modified 2 years, 3 months ago by zzz.
    #14604
    zzz
    Delete this post thank you. It just mean, I need to trust the certificate in the server setting.
  • The topic ‘KepwareEx rejects RS6 cert’ is closed to new replies.
