Forum Home › Forums › Development and Integration › Integration issue
- This topic has 4 replies, 2 voices, and was last updated 10 years, 2 months ago by
September 22, 2016 at 4:44 pm #1621
solmann
ParticipantSir,
I am trying to use moddbexport module with postgres sql.
I am getting following error:-
password authetication failed for user…. I have created user properly in admin and password also with application prevelage...screen shots :-
https://postimg.org/image/yg3te2skp/
http://postimg.org/image/aley1rdk1/Logs of DB export error as under
nnecting to DB PostgreSQL – localhost: FATAL: 28P01: password authentication failed for user “export”
Error connecting to DB PostgreSQL – localhost: FATAL: 28P01: password authentication failed for user “export”
more info
Server config user.dat is updated.. and looks good with required usersany clue…
September 23, 2016 at 5:42 am #1622
MikhailModeratorTry using these manuals:
https://www.postgresql.org/docs/9.1/static/client-authentication-problems.html
https://www.postgresql.org/docs/9.3/static/auth-pg-hba-conf.html
http://stackoverflow.com/questions/21388701/postgresql-sspi-authentication-fatal-2801-password-authentication-failed-forThis issue is not caused by ModDBExport but the PostgreSQL itself.
September 24, 2016 at 7:50 am #1626solmann
ParticipantI am trying for that,
Also let me know where to spcify port number for oracle db export.
as sql devloper specify for port 1521,,
…. i am trying various combination but error listener refuse connection. ORA12505.. any clue??
at Scada server templets there is a server connection tab also … do i need to play with it…
September 24, 2016 at 11:52 am #1628
MikhailModerator1521 is the default Oracle port. I don’t think you should explicitly specify it.
Have you specified your connection settings in tnsnames.ora ?Connection tab contains settings those used by the shell to connect to SCADA-Server service. You don’t need to change them.
September 24, 2016 at 11:54 am #1629
MikhailModeratorThe most simple is MySQL and MS SQL 🙂
