Input channel (small bug)
Forum Home Forums Understanding the Software Input channel (small bug)
  • This topic has 1 reply, 2 voices, and was last updated 3 years ago by JW.
  • #10872
    victorlam
    https://drive.google.com/file/d/1QFTgWVGHHWrNxHEAdik_zLMTRRyz-AFR/view?usp=sharing
    Please find the screenshot as shown as above.
    I would like to add 40008 register address and the indicated box Address cannot be edited or changed. In order to add 40008, I need to add the un-necessary input channel numbers 40006 and 40007 and then I can add 40008 register address.
    Please advise if this is the method to solve the issue for adding the register address not in a continuous sequence order. eg 30001, 30004, 30006.
    #10877
    JW
    Hi, I think it’s a feature related to modbus protocol.
    Each element group equals 1 modbus request command, which can only get upto 100 consecutive address.
    to add 30001, 30004, 30006, it can be done by adding 1 element group of read holding register (0x03) with starting elelment address 1 and elelment count of 6.
    when creating input channels, singals 1,4,6 can be used while singals 2,3,5 can be ignored.
    this is the fastest way because there will be only 1 modbus request.
    another way is to add 3 element gourps of read holding register (0x03) with starting address 1,4,6 respectively.
    this way is slower beacause there will be 3 requests.
    you will slao need to config the dalay between each requst in communication line settings.
