How to use the Custom Archive (bit 16)?
Forum Home › Forums › Understanding the Software › How to use the Custom Archive (bit 16)?
  • #18162
    Andi
    While learning Rapid SCADA, I noticed that the Archive Mask dialog contains bit 16: Custom archive.
    I checked my ScadaServerConfig.xml, but it only contains the standard archives:
    -Current
    -Minute
    -Hour
    -Day
    -Events
    -Current Copy
    -Minute Copy
    -Hour Copy
    -Day Copy
    -Event Copy
    There is no archive with code “Custom”, and searching the configuration for the word “Custom” returns no results.
    Therefore I would like to understand:
    1. What is the purpose of the Custom Archive bit?
    2. How can a custom archive be defined?
    3. Can a custom archive use a different writing interval (for example every 10 seconds or every 30 seconds)?
    4. Is there any documentation or example available?
    Thank you very much for your help!
    #18163
    Step 1 – Create an archive in Instances – Default – Server – Archives
    Step 2 – add the created archive with the bit indication to the secondary table
    WritingPeriod – The recording period starts from 1 second
    • This reply was modified 3 months, 1 week ago by manjey73.
    #18168
    To push users create new custom archives with ID >= 101 and bit >= 16.
    Sure.
    Use the existing archives as examples. Post screenshots on the forum if new archives don’t work.
    #18169
    Andi
    Thank you both for your quick and helpful answers. They helped me understand the concept of custom archives much better. I really appreciate your support and the time you took to answer my questions.
    #18176
