How to extract MQTT message completely
Forum Home › Forums › Communicating with Devices › How to extract MQTT message completely
  • #14495
    kcks66
    Hi Mikhail,
    I am testing a MQTT client connection setup in V6. I follow the forum and managed to connect to Local Mosquitto Broker and subscribe a topic. The message is look like below:
    https://ibb.co/rp62J0s
    I configure the Device Properties like below:
    https://ibb.co/Jxn6ZBH
    I created a JS file and locate at C:\Program Files\SCADA\ScadaComm\Config as suggest:
    https://ibb.co/xf86dvh
    The only thing I couldn’t follow is the Sub items which I don’t know what to fill into the String Collection Editor. My String Collection Editor is different from those from forum example.
    I got error:
    https://ibb.co/G7TgjWF
    As the result, I couldn’t get the Voltage L1, L2 and L3 values:
    https://ibb.co/5xc59yK
    Need your advice on how to complete my configuration.
    #14498
    You need subitems as Voltage L1, Voltage L2 and Voltage L3. And only 1 subscription,
    #14500
    kcks66
    Hi Mikhail,
    Could you give example of how to write in subitems for my case?
    #14501
    kcks66
    I try like this but no luck
    https://ibb.co/BjrrfFc
    #14503
    Create only 1 subscription, named Voltage (delete 2 others). The subscription should contain 3 sub items (3 lines).
    #14506
    kcks66
    Hi Mikhail,
    That’s great. I can read all the Voltage L1, L2 and L3 now.
    #14508
    Could you share the final settings? It can be useful for other users.
    #14512
    kcks66
    Hi Mikhail,
    My final setting, with many other parameters:
    https://ibb.co/Wsr8HW3
    #14513
