How to avoid entering password everytime when entering the set point
Forum Home › Forums › Development and Integration › How to avoid entering password everytime when entering the set point
  • #9697
    dp_palai
    Whenever I click on a dynamic text to enter the value, windows pop up and it asks to enter the password and the value. But I want to configure so that the user does need to enter a password. He only will enter the set point value.
    #9699
    You can change it in the configuration of the web application.
    http://localhost/scada/plugins/Config/WebConfig.aspx
    After changing don’t forget to download the new settings into your project.
    #9700
    dp_palai
    Hi Mikhail, Hope you are doing well. Thanks a lot for the fast response. The required configuration is done. Thanks for that.
    I find this software very interesting but as I am using it the first time, facing some problems configuring it as per our requirement.
    Please help me with this configuration. I want to configure a data entry point where, when I click on it, it asks for data entry and after data is entered, data appears at the same place.
    By now, I could configure to enter data by clicking a dynamic text, but could not configure it so that data will appear at the same place.
    Maybe I should use a different component for that, I am not getting that. Please help me. Thanks in advance.
    #9701
    dp_palai
    Hi Mikhail, The configuration I was asking for in my previous post, is done. Thanks.
    #9702
    OK 🙂
