I am working on a system for email sending when pressing a button. I have already made the email sender work with the method you recommend in other posts:
My question is, is there any method to fix that message/string data for this command, so when combined with the send command now function, you could send a fixed message to a fixed list of contacts just with the push of the Dynamic Picture?
Yes, you need Automatic Control Module that helps you.
Using this module you can send Binary command by a trigger that is a Standard command sent by clicking an image.
This reply was modified 8 years, 1 month ago by Mikhail.
I have tried and it works as expected, thanks! 🙂
I have another doubt, I can see that the automatic control module works well, and tested both the channel data trigger and the time trigger.
The question is, is it possibe to combine both of them, so the trigger condition is, if the channel data at a certain time exceeds X value, to send a command?
