Elastic Report – formulas
Forum Home Forums Understanding the Software Formulas Elastic Report – formulas
  • #14089
    gabeirinhas
    By applying the following formula I get the difference correctly, as well as the total of the difference obtained.
    <Column name=”Dif” calcType=”Diff” calcTotal=”true” calcAvg=”true” calcMin=”true” calcMax=”true” />
    I have applied a multitude of calcType=”Formula”, so that the calcTotal is only applied to those values obtained that are negative.
    I am running out of ideas, is there any way to do this, or is it not possible, I am using rapid scada v5, thanks for your help.
    #14091
    Formulas that calculate totals are predefined. Unfortunately, you can’t calculate only negative values in the described case.
    However, a section of the DataData type can contain a custom formula. May be you can use a custom formula in the DataData section that refers the previous TimeData section.
    Note: Elastic Report formulas work only in Excel format.
    Note2: Elastic Report 6 supports XLSX format instead of Office XML 2003.
