Disable / Hide toggle
Forum Home › Forums › Understanding the Software › Disable / Hide toggle
  • #6666
    Luca
    How to disable/enable or hide/show a Toggle depending of the content of an input channel?
    I tried to put a dinamic image over the toggle but no success.
    #6668
    You can cancel the command from a toggle depending on a channel value, but you can’t hide it.
    #6669
    Luca
    Please Mikhail can you provide an example how to cancel a command from a toggle depending on a channel value?
    Thank you
    #6672
    Set the formula of the output channel like the example below.
    Val(101) >= 100 && Stat(101) > 0 ? Cmd : double.NaN
    If the formula returns double.NaN, command is cancelled. And you will see an appropriate message in the Server log file.
    #6688
    Luca
    Thank you Mikhail, it works fine.
