Device selection by first package
Forum Home › Forums › Communicating with Devices › Modbus › Device selection by first package
  • #5357
    cooldjmc
    Hi, i would like to know if someone can help about when setting a TCP Server and want to idetify device by first package what format is used, —- and after that i assume that that id must be put on call adress. Please if someone, know about this funcion explain how must be used.
    #5359
    1. A device is TCP client. Right after it connects to Communicator (TCP server), it sends a string that identifies this device.
    2. Communicator compares the given string with “Call Number” of existing devices. If matched, communication continues.
    #5368
    cooldjmc
    thank you for answer, but that string how is interpreted in comunicator ? maybe as ascii?
    Receive (4/4): ˇˇ^^
    the value that the device send is 41377 witch hex is a1 a1 followed by e5 e5 and the comunicator intrprets like this: Receive (4/4): ˇˇ^^
    Exists a method that comunicator intrpret id’s like decimal numbers ?
    #5370
    Yes, Communicator interprets like ASCII.
    We can update Communicator to support HEX, but currently our team is working hard, so we can implement the changes on commercial way.
