Dashboard cell size
Forum Home Forums Understanding the Software Dashboard cell size
  • #15291
    saskrabic
    Hi.
    Inside of example Dashboard1.xml we can see that we can set width of every column inside 1-12 range. Height of the row we set width aspect ratio.
    Is it possible to define size of a field in exact value of pixels? I would like to create a field that will show “Custom url” and I would like that to be 1024*768 px.
    Best regards!
    #15297
    Widget width can only use relative quantities from 1 to 12, because the plugin is based on Bootstrap grid system, which makes widgets stretchable.
    If you need a fixed size, try a Frame component from Extra Scheme Components.
