Forum Home › Forums › Development and Integration › create new type Static Link
- This topic has 3 replies, 2 voices, and was last updated 10 years, 5 months ago by
June 25, 2016 at 11:52 am #1338
evil.scorpi@gmail.com
Participanthi
i try to make new type(staticLink) in the scadaSchemeEditor so i make new type in
SchemeView.Types
SchemeView
and
ScadaSchemeSvc
but after compile code and run the program i get the exeption
WCF service error: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter http://tempuri.org/:schemeChange. The InnerException message was ‘Invalid enum value ‘staticLink’ cannot be deserialized into type ‘Scada.Scheme.ScadaSchemeSvc.SchemeViewElementTypes’. Ensure that the necessary enum values are present and are marked with EnumMemberAttribute attribute if the type has DataContractAttribute attribute.’. Please see InnerException for more details.
i trace the program i i find in the line
editorData.SchemeChange = change;
in the file ScadaSchemeSvc.svc in scadaSchemeCommon
it get throw exeption
what can i do for that and what was it made.
thanks for your helpJune 25, 2016 at 6:08 pm #1342
It’s difficult to answer without debugging. I assume that web service autogenerated code must be updated using VS.
The core of schemes will be significantly redesigned this year. It may cause double work for you. The prototype of the new web app is here http://demo.rapidscada.net
Login and password are admin/12345It is planned to support 3rd party controls to allow developers creating their own components, but API hasn’t been developed yet.
June 25, 2016 at 6:38 pm #1343evil.scorpi@gmail.com
Participantthanks for your answers
but i can not understand the problem
i try to change the action command and add new action type but the same problem seen.
WCF service error: The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter http://tempuri.org/:schemeChange. The InnerException message was ‘Invalid enum value ‘OpenLink’ cannot be deserialized into type ‘Scada.Scheme.ScadaSchemeSvc.SchemeViewAction’. Ensure that the necessary enum values are present and are marked with EnumMemberAttribute attribute if the type has DataContractAttribute attribute.’. Please see InnerException for more details.
i check the new schemaweb but the core library completely diffrent from the current version.
it will be the please to help solving the problemJune 26, 2016 at 6:53 am #1344
MikhailModeratorGo to SchemeViewAction class defenition in ScadaScheme silverlight project (by pressing F12). It’s in the file Reference.cs that is “generated by a tool.” You have to right click ScadaSchemeSvc in solution explorer and update service reference. You need the value “OpenLink” be added to the service reference class defenition.
