I checked the forum that there was discussion about the creation of event.
Can you clarify further how can I create a event? And where is the event located in the system? in Communicator or Server or directory?
My ultimate goal is to create an event and check the status of register eg 30001 or 40001 if the value = 1 or other values. Then it will be alert via notification module that will be purchased soon.
Events are created automatically by the Server application depending on channel properties. You should set event checkboxes for the channel. Events are stored in the event archive, located by default in C:\SCADA\ArchiveDAT\Events
