Create a Virtual Device using communication and OPC
Forum Home › Forums › Communicating with Devices › OPC › Create a Virtual Device using communication and OPC
  • #5605
    dsantiago
    Mikhail:
    I have 3 computers and I wish to make 1. SCADA Server (Full Install of Rapid SCADA)
    2. RTU (Communicator Installed) and 3. A virtual device that (not sure what to install I am thinking the Communicator and the OPC), please advise on this third machine.
    These will all be run as separate VMs on Virtual Box, I want them all to communicate with each other so far computer 1 and computer 2 are talking. I just need to know what to install on the third virtual machine that I want to use as a virtual device.
    Thank you so much,
    Dawn
    #5606
    Hi Dawn,
    I suggest Rapid SCADA 5.7.x
    On the 1st VM install all the apps.
    On the 2nd and 3rd install Communicator and Agent.
    As virtual device you can choose Martrikon OPC simulation server or use the included in Rapid SCADA KpSimulator.dll driver.
    #5608
    dsantiago
    Mikhail:
    When you say agent you mean the modbus and OPC, is this correct.
    Thank you,
    Dawn Silverman
    #5611
    dsantiago
    Mikhail:
    How do I connect the 1st VM and the 2nd VM to the communicator. We installed 5.6 on 1st computer, 2nd computer we have communicator and agent.
    Thank you,
    Dawn
    #5612
    Agent is the application of Rapid SCADA. Agent is included in Rapid SCADA 5.7.
    When you install Rapid SCADA 5.7, you will connect to VMs from Administrator installed on your workstation PC.
    #5613
    dsantiago
    Mikhail:
    ALL of the machines are VMs. Do you mean the main VM with all software installed?
    Thank you,
    Dawn
    #5614
    dsantiago
    It is not doing this automatically how to we make sure they can communicate???
    Thank you,
    Dawn
    #5621
    Yes, the main.
    Please clarify what is going on. Screenshots usually help to understand.
