Could you help to make correct logic.
Forum Home › Forums › Understanding the Software › Formulas › Could you help to make correct logic.
  • #5451
    scadarapid
    Hi.
    there are 2 inputs and 1 output.
    my purpose
    if input1 = off and input2 = on , my output will be on after that my output will alway on even though input1 change on/off. the only way to make my output off is input 2 must off then my output = 0.
    this is my formula
    public double inputtest(double in1,double in2)
    double output = 0;
    int a = 0;
    if(in1 == 0 && in2 > 0 && a == 0){
    output = 1;
    a = 1;
    if(a == 1 && in2 == 0){
    output = 0;
    a = 0;
    return Convert.ToDouble(output);
    Thank you so much.
    #5452
    Tell me, why do you then need to input 1 ?
    #5453
    scadarapid
    Thank you so much
    I use this formula and it work fine.
    public double ifS(double in1,double in2,double in3)
    double output = in3;
    if(in1 == 0 && in2 == 1){
    output = 1;
    }else if(in2 == 0){
    output = 0;
    return output;
