Copy automatic control module configurations
Forum Home Forums Understanding the Software Copy automatic control module configurations
  • #13186
    kcks66
    Hi Mikhail,
    I had done configuration of automatic control module from my test server and tested function well. Now I want my production server’s automatic control module configuration have the exact configuration like my test server’s.
    I copied and pasted the ModAutoControl.xml config file from test server to production server, as the result my production server doesn’t has the desired configurations.
    Pls advice for is there a possibility to copy configurations in between machines? Or I have no choice to re-configure again in my production server.
    #13189
    you have to copy the configuration between the project folders
    #13193
    kcks66
    Hi manjey73,
    That’s great. Thank you.
