Connection through VPN error
Forum Home › Forums › Communicating with Devices › Modbus › Connection through VPN error
  • #12173
    feltduck
    Hi, I’m trying to connect to my Raspberry Pi through VPN and in response I’m getting “Communication error”. I tried this before in local and it went well, all of this with a ModBus server installed on the Pi.
    This is the line log
    2023-03-06 12:36:25 Establish a TCP connection with 10.79.253.197:502
    2023-03-06 12:36:26 Communication session with the Device 10 “Prueba”, type: KpModbus, address: 10, call number: 10.79.253.197
    Request element group
    Send (12): 01 1B 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Communication error!
    Send (12): 01 1C 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 01 1D 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    2023-03-06 12:36:29 Disconnect from 10.79.253.197
    2023-03-06 12:36:29 Establish a TCP connection with 10.79.253.197:502
    2023-03-06 12:36:30 Communication session with the Device 10 “Prueba”, type: KpModbus, address: 10, call number: 10.79.253.197
    Send (12): 01 1E 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 01 1F 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 01 20 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    #12182
    You can connect to the device, but it does not respond. Check that the Modbus device address is correct. Use https://rapidscada.net/modbus to validate the packets: 01 1E 00 00 00 06 0A 03 00 00 00 0A
    #12183
    Also possible that requests are not delivered to RPi by VPN.
    #12195
    feltduck
    I’ll check if the RPi doesn’t deliver the request trough VPN.
    Now I have another problem. I’m trying to connect again on local and it doesn’t work.
    This is the log that I’m getting:
    2023-03-07 08:57:33 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:33 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Send (12): 00 A9 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AA 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AB 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    2023-03-07 08:57:37 Disconnect from 192.168.1.103
    2023-03-07 08:57:37 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:37 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Send (12): 00 AC 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AD 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AE 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    2023-03-07 08:57:41 Disconnect from 192.168.1.103
    2023-03-07 08:57:41 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:42 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Send (12): 00 AF 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 B0 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 B1 00 00 00 06 0A 03 00 00 00 0A
    Receive (7/7): 00 AF 00 00 00 03 0A
    Incorrect MBAP Header data!
    #12196
    Modbus server does not respond. You should check logs of Modbus server if it provides info.
    #12201
    feltduck
    I just reinstalled the modbus server and the scada and it’s going well.
    Now the doubt that I have is, how can I export all the data to a XML?
    Thanks for the help.
    #12202
    Please create a new topic for the new question and provide the details.
