Config for Mod disappeared when I upload
Forum Home › Forums › Runtime Bugs › Server Bugs › Config for Mod disappeared when I upload
  • #7530
    yuemiao
    The Mod is my newly written code,the configuration it depends on always disappeared when I upload,Is it a bug?
    #7535
    Could you clarify the question?
    May be you should check that the configuration is located inside your project.
    #7542
    yuemiao
    C:\SCADA\ScadaServer\Config,I put config in this path
    #7544
    yuemiao
    In mod,send command ,return false,why?
    CommSettings settings = new CommSettings(ip, 10000, “ScadaServerCtrl”, “12345”, 1000);
    Log log = new Log(Log.Formats.Full);
    ServerComm = new ServerComm(settings, log);
    private bool SendCnd(int ctrlCnlNum, double cmdData)
    bool sendOk;
    sendOk = ServerComm.SendStandardCommand(3, ctrlCnlNum, cmdData, out bool result);
    WriteToLog(“ctrlCnlNum: “+ ctrlCnlNum+ ” cmdData: “+ cmdData, Log.ActTypes.Action);
    WriteToLog(sendOk.ToString(), Log.ActTypes.Information);
    return sendOk;
    SendCnd(102, 0);
