Forum Home › Forums › Communicating with Devices › OPC › Communicating with Kepware OPC server
- This topic has 9 replies, 5 voices, and was last updated 4 years, 7 months ago by
hismail.sa@gmail.com.
October 5, 2018 at 11:55 am #4348
Hennie_KotzeParticipantGood day,
I have recently installed Rapid SCADA, and was hoping someone could provide some assistance with the correct setup for communicating with my existing OPC server.
We are using KepserverEX, from Kepware:
https://www.kepware.com/en-us/products/kepserverex/Currently our plant is operated by Wonderware SCADA, but I would like to have a SCADA in all my manager’s offices as well. Wonderware is too expensive for several licenses, so Rapid SCADA sounds like the perfect product.
Hopefully someone out there has already used Rapid SCADA with kepware?
Regards,
Hennie Kotze
October 5, 2018 at 2:00 pm #4349
MikhailModeratorHello Hennie,
Currently, I have no information about using Kepware with Rapid SCADA. However it’s easy to check.
You should install Rapid SCADA or at least Communicator on the PC where OPC server exists. Then follow this video.In case of questions, ask here. Please share your result.
April 10, 2021 at 4:00 am #8703tranduong257
ParticipantHi Hennie,
Did you connect Rapid SCADA to KepEX OPC successful? Can you help me to do this, i have some trouble now, thank you!April 12, 2021 at 3:38 am #8706
Hennie_KotzeParticipantHi tranduong257,
I did manage to get it working yes, but I don’t have that project with me at the moment, I will have to create a new one if I want to remember how I did it.
What are you struggling with?
Regards,
April 12, 2021 at 7:52 am #8707tranduong257
ParticipantHi Hennie, I’m glad you reply to me. Now i am having a trouble that when I upload configuration after I had choosed the tag from KepEX OPC and created a table view on rapid, The Screen show that “Error uploading onfiguration, there was no endpoint listening at http://localhost:10002/ScadaAgent/ScadaAgentSvc/ that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more detail”.
Could you tell me what i need to do, or do you have any document about your last project?
Sincerely,April 12, 2021 at 1:39 pm #8713
MikhailModeratorApril 12, 2021 at 4:08 pm #8717
Sorry I did not encounter any of those errors… I Whish I could be of more assistance but I cant, sorry.
Regards,
Hennie
August 24, 2021 at 3:06 pm #9420Daryl
I had a successful connection to OPC and OPC UA using KepserverEX and receiving data for both communication lines. However for the OPCUA communication line, the Channel won’t bind to the tag. Any solution?
August 24, 2021 at 3:26 pm #9421
Please provide screenshots of the related settings and the device state page (in Administrator).
January 12, 2022 at 9:59 am #9895hismail.sa@gmail.com
ParticipantHi @hennie_kotze,
I need some assistance with Rapid SCADA and was told to speak to you. How can I contact you to discuss what I need done.
Regards,
Hussein Ismail-
This reply was modified 4 years, 7 months ago by
