Chart Pro Installation
Forum Home › Forums › Runtime Bugs › Webstation Bugs › Chart Pro Installation
  • #6582
    roska
    I updated the Software to 5.8.0 and also upgraded the hardware, so I need to buy a new Chartpro License. I downloaded the plugin, copied to the harddisk, and unblocked the dll.
    When I want to see the installed plugins, ChartPro is missing.
    I checked the webstation log, and there is an error:
    2020-03-06 11:43:51 <computername><DefaultAppPool><ERR> Unable to get the plugin type Scada.Web.Plugins.PlgChartProSpec from the assembly C:\SCADA\ScadaWeb\bin\PlgChartPro.dll:
    Die Datei oder Assembly “ScadaWebCommon5, Version=5.0.7.0, Culture=neutral, PublicKeyToken=null” oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
    The last part of the error translates to something like:
    The File or Assembly “ScadaWebCommon5, Version=5.0.7.0, Culture=neutral, PublicKeyToken=null” or a dependency of it was not found. The system can not find the specified file.
    #6584
    if ScadaWebCommon5.dll exists, delete it. The actual library is ScadaWebCommon.dll
    Also make sure that Chart Pro plugin is up to date.
    The repository provides more info about version compatibility.
