channel status in database mysql
Forum Home › Forums › Development and Integration › channel status in database mysql
  • #8666
    afzal
    I am getting data in mysql database,
    i have three columns
    date channel status
    i want to see the status value change after 20 minutes, to go from 1 to 2, then 3, then 4…
    basically i am generating an interrupt on output channel 0 to 1 or 1 to 0 every 20 minutes. and my input channel values change after 20 minutes.
    so in order to see the variation in input channel after 20 minutes i want the status to change.to go from 1, to 2 then 3, 4, 5, …
    where can i implement this logic and how ?
    #8679
    DB export module executes SQL script every time when data comes from Communicator to Server. If you need custom data processing, it should be implemented on database level.
