Calculated input/output channels
Forum Home › Forums › Understanding the Software › Calculated input/output channels
  • #17041
    oley
    I need a control algorithm based on data:
    – beginPeriod : DateTime
    – endPeriod : DateTime
    – value : double
    The user should be able to set those three channels and based on the values automatic control module should set another physical device channel.
    I have created (DataType:double, Format:DataTime) calculated/output channel, which I can modify from the view, but it does not store this value.
    #17042
    to enter the time into the channel, with the Time format, an output formula is needed.
    #17043
    Output script GetStrDtToUtc(CmdDataStr) the format of the command “Date and Time”
    Input script Val() the format “Date and Time”
    in table script
    public double GetStrDtToUtc(string dt)
    SetVal(CnlNum, EncodeDate(DateTime.Parse(dt).ToUniversalTime()));
    return EncodeDate(DateTime.Parse(dt).ToUniversalTime());
    #17044
    A calendar should be called to enter the time and date.
    #17045
    oley
    thank you, it works.
    Another question: how to setup channel, which will be an Off-On and use it with toggle and led on a scheme view?
    #17046
    It’s simple.
    Set the output formula to SetData()
    Channel type is calculated/output.
    #17061
    oley
    I figured it out myself before I read the answer. Thanks!
