After using Rapid Scada, individual ideas make suggestions
Forum Home › Forums › New Ideas › After using Rapid Scada, individual ideas make suggestions
  • #15877
    詹森
    1. When editing Channels, the direct save (ctrl+s) will show that no save takes effect, that is, the modified asterisk has disappeared, but the actual save is not saved, and you need to “Apply Edit Operation” every time to ensure the save
    2. It is hoped that the content of Logs can be copied directly on the Logs page
    3. It is hoped that other data can be viewed during Upload, so that other actions can be performed without waiting for the Upload to complete. The upload progress can be put in the upper right corner as a progress bar, and if the upload fails, an error symbol will be displayed. Generally, the upload succeeds instead of waiting for uploading without doing anything. This can increase the efficiency of software development.
    Whether approved or not, we look forward to your reply!
    #15885
    Thank you for your thoughts.
    Item 2. You can. Try Ctrl + C.
    Items 1 and 3 have been added to the back log.
    #15891
    詹森
    OKay,Thank you.
